Saving RAM by declaring thread functions "noreturn"
One of the problems, when writing embedded multi-threaded applications, is that the thread functions do save the registers in the function entry code even if the system does not require it, exiting such a function would terminate the thread so there is no need to preserve the register values, this can waste tens of bytes for each thread.
The problem
Consider the following code:
#include <ch.h>
static WORKING_AREA(waMyThread, 64);
static t_msg MyThread(void *arg) {
  while (!chThdShoudTerminate()) {
    /* Do thread inner work */
  return 1;
main() {
  chSysInit();
  chThdCreateStatic(waMyThread, sizeof(waMyThread), NORMALPRIO, MyThread, NULL);
The resulting ASM code for the thread function would be something like this:
MyThread:
        stmfd   sp!, {r4, r5, r6, lr}
        ldmfd   sp!, {r4, r5, r6, pc}
Being that function a thread there is no need to save those registers, in embedded applications often the RAM is a scarce resource.
The solution
Stack space can be saved by modifying the code as follow, using an useful GCC extensions:
#include <ch.h>
__attribute__((noreturn))
static void MyThread(void *arg) {
  chThdExit(1);
main() {
  chSysInit();
                    (tfunc_t)MyThread, NULL);
This will make GCC believe that the function cannot return and there is no need to save registers. The code will be a bit less readable and less portable on other compilers however.
chibios/kb/saveram.txt · Last modified: 2011/10/03 20:57 by giovanni
