Differences
chibios:kb:priority [2010/12/25 08:47]
giovanni [Threads at equal priority]
chibios:kb:priority [2011/10/03 20:53] (current)
giovanni [Priority Levels]
Line 1: Line 1:
 ====== Priority Levels ====== ====== Priority Levels ======
 +<HTML>
 +<table>
 +<tr>
 +<td>
 +</HTML>
 Priority is an important concept when using a RTOS, ChibiOS/RT is no different in this regard. Priority is an important concept when using a RTOS, ChibiOS/RT is no different in this regard.
 +<HTML>
 +</td>
 +<td>
 +<!-- Place this tag where you want the +1 button to render -->
 +<div align="right">
 +<g:plusone size="tall"></g:plusone>
 +</div>
 +</td>
 +</tr>
 +</table>
 +<!-- Place this tag after the last plusone tag -->
 +<script type="text/javascript">
 +  (function() {
 +    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
 +    po.src = 'https://apis.google.com/js/plusone.js';
 +    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
 +</script>
 +</HTML>
 ===== Priorities in ChibiOS/RT ===== ===== Priorities in ChibiOS/RT =====
chibios/kb/priority.txt · Last modified: 2011/10/03 20:53 by giovanni
Except where otherwise noted, content on this wiki is licensed under the following license:GNU Free Documentation License 1.3
