Differences
chibios:howtos:stop_os [2010/12/04 16:08]
127.0.0.1 external edit
chibios:howtos:stop_os [2011/10/03 20:50] (current)
giovanni [How to cleanly stop the OS]
Line 1: Line 1:
 ====== How to cleanly stop the OS ====== ====== How to cleanly stop the OS ======
 +<HTML>
 +<table>
 +<tr>
 +<td>
 +</HTML>
 Stopping the OS should not be normally required but there are scenarios where one might want the complete control over the system again, for example entering into a bootload mode, or invoking some flashing algorithm locked in ROM. Stopping the OS should not be normally required but there are scenarios where one might want the complete control over the system again, for example entering into a bootload mode, or invoking some flashing algorithm locked in ROM.
 +<HTML>
 +</td>
 +<td>
 +<!-- Place this tag where you want the +1 button to render -->
 +<div align="right">
 +<g:plusone size="tall"></g:plusone>
 +</div>
 +</td>
 +</tr>
 +</table>
 +<!-- Place this tag after the last plusone tag -->
 +<script type="text/javascript">
 +  (function() {
 +    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
 +    po.src = 'https://apis.google.com/js/plusone.js';
 +    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
 +</script>
 +</HTML>
 ===== The Problem ===== ===== The Problem =====
chibios/howtos/stop_os.txt · Last modified: 2011/10/03 20:50 by giovanni
Except where otherwise noted, content on this wiki is licensed under the following license:GNU Free Documentation License 1.3
