STM32L-Discovery demo code
    ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
                 2011 Giovanni Di Sirio.
    This file is part of ChibiOS/RT.
    ChibiOS/RT is free software; you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation; either version 3 of the License, or
    (at your option) any later version.
    ChibiOS/RT is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include "ch.h"
#include "hal.h"
#include "test.h"
static void pwmpcb(PWMDriver *pwmp);
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n);
static void spicb(SPIDriver *spip);
/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS   2
/* Depth of the conversion buffer, channels are sampled four times each.*/
#define ADC_GRP1_BUF_DEPTH      4
 * ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
 * ADC conversion group.
 * Mode:        Linear buffer, 4 samples of 2 channels, SW triggered.
 * Channels:    IN10   (48 cycles sample time)
 *              Sensor (192 cycles sample time)
static const ADCConversionGroup adcgrpcfg = {
  FALSE,
  ADC_GRP1_NUM_CHANNELS,
  adccb,
  NULL,
  /* HW dependent part.*/
  0,
  0,
  0,
  ADC_SMPR2_SMP_AN10(ADC_SAMPLE_48) | ADC_SMPR2_SMP_SENSOR(ADC_SAMPLE_192),
  0,
  ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
  0,
  0,
  0,
  ADC_SQR5_SQ2_N(ADC_CHANNEL_IN10) | ADC_SQR5_SQ1_N(ADC_CHANNEL_SENSOR)
 * PWM configuration structure.
 * Cyclic callback enabled, channels 3 and 4 enabled without callbacks,
 * the active state is a logic one.
static PWMConfig pwmcfg = {
  10000,                                    /* 10KHz PWM clock frequency.   */
  10000,                                    /* PWM period 1S (in ticks).    */
  pwmpcb,
    {PWM_OUTPUT_ACTIVE_HIGH, NULL},
    {PWM_OUTPUT_DISABLED, NULL},
  0
 * SPI configuration structure.
 * Maximum speed (12MHz), CPHA=0, CPOL=0, 16bits frames, MSb transmitted first.
 * The slave select line is the pin GPIOA_SPI1NSS on the port GPIOA.
static const SPIConfig spicfg = {
  spicb,
  GPIOB,
  12,
  SPI_CR1_DFF
 * PWM cyclic callback.
 * A new ADC conversion is started.
static void pwmpcb(PWMDriver *pwmp) {
  (void)pwmp;
  /* Starts an asynchronous ADC conversion operation, the conversion
     will be executed in parallel to the current PWM cycle and will
     terminate before the next PWM cycle.*/
  chSysLockFromIsr();
  adcStartConversionI(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
  chSysUnlockFromIsr();
 * ADC end conversion callback.
 * The PWM channels are reprogrammed using the latest ADC samples.
 * The latest samples are transmitted into a single SPI transaction.
void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
  (void) buffer; (void) n;
  /* Note, only in the ADC_COMPLETE state because the ADC driver fires an
     intermediate callback when the buffer is half full.*/
  if (adcp->state == ADC_COMPLETE) {
    adcsample_t avg_ch1, avg_ch2;
    /* Calculates the average values from the ADC samples.*/
    avg_ch1 = (samples[0] + samples[2] + samples[4] + samples[6]) / 4;
    avg_ch2 = (samples[1] + samples[3] + samples[5] + samples[7]) / 4;
    chSysLockFromIsr();
    /* Changes the channels pulse width, the change will be effective
       starting from the next cycle.*/
    pwmEnableChannelI(&PWMD4, 0, PWM_FRACTION_TO_WIDTH(&PWMD4, 4096, avg_ch1));
    pwmEnableChannelI(&PWMD4, 1, PWM_FRACTION_TO_WIDTH(&PWMD4, 4096, avg_ch2));
    /* SPI slave selection and transmission start.*/
    spiSelectI(&SPID2);
    spiStartSendI(&SPID2, ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH, samples);
 * SPI end transfer callback.
static void spicb(SPIDriver *spip) {
  /* On transfer end just releases the slave select line.*/
  chSysLockFromIsr();
  spiUnselectI(spip);
 * This is a periodic thread that does absolutely nothing except increasing
 * a seconds counter.
static WORKING_AREA(waThread1, 128);
static msg_t Thread1(void *arg) {
  static uint32_t seconds_counter;
  (void)arg;
  chRegSetThreadName("counter");
  while (TRUE) {
    chThdSleepMilliseconds(1000);
    seconds_counter++;
 * Application entry point.
int main(void) {
   * System initializations.
   * - HAL initialization, this also initializes the configured device drivers
   *   and performs the board-specific initializations.
   *   RTOS is active.
  halInit();
  chSysInit();
   * Activates the serial driver 1 using the driver default configuration.
   * PA9 and PA10 are routed to USART1.
  sdStart(&SD1, NULL);
  palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7));
   * If the user button is pressed after the reset then the test suite is
   * executed immediately before activating the various device drivers in
   * order to not alter the benchmark scores.
  if (palReadPad(GPIOA, GPIOA_BUTTON))
    TestThread(&SD1);
   * Initializes the SPI driver 2. The SPI2 signals are routed as follow:
   * PB12 - NSS.
   * PB13 - SCK.
   * PB14 - MISO.
   * PB15 - MOSI.
  spiStart(&SPID2, &spicfg);
  palSetPad(GPIOB, 12);
  palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
                           PAL_STM32_OSPEED_HIGHEST);           /* NSS.     */
  palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* SCK.     */
  palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5));              /* MISO.    */
  palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* MOSI.    */
   * Initializes the ADC driver 1 and enable the thermal sensor.
   * The pin PC0 on the port GPIOC is programmed as analog input.
  adcStart(&ADCD1, NULL);
  adcSTM32EnableTSVREFE();
  palSetPadMode(GPIOC, 0, PAL_MODE_INPUT_ANALOG);
   * Initializes the PWM driver 4, routes the TIM4 outputs to the board LEDs.
  pwmStart(&PWMD4, &pwmcfg);
  palSetPadMode(GPIOB, GPIOB_LED4, PAL_MODE_ALTERNATE(2));
  palSetPadMode(GPIOB, GPIOB_LED3, PAL_MODE_ALTERNATE(2));
   * Creates the example thread.
  chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO, Thread1, NULL);
   * Normal main() thread activity, in this demo it does nothing except
   * sleeping in a loop and check the button state, when the button is
   * pressed the test procedure is launched with output on the serial
   * driver 1.
  while (TRUE) {
      TestThread(&SD1);
    chThdSleepMilliseconds(500);
chibios/articles/stm32l_discovery/code.txt · Last modified: 2011/10/04 17:29 by giovanni
